Reading Sn_IR - gives 0xFF ??
RE: Reading Sn_IR - gives 0xFF ??
by ngaihua ·
i found out the reason for the above behavior. This is due to oversight on my part.
When Interrupt handler, does a SPI read, while a SPI write is in progress in the main loop, it corrupts the main loop SPI write. This results in undefined behavior and crashes W5500.
To solve the problem, I disabled any interrupts while SPI read/write operation is in progress.
