W5500 Support SSL ?
RE: W5500 Support SSL ?
by Mxyxixptlick ·
Yes. I use wolfSSL with a system built from an Adafruit Metro M4 Express and a W5500 shield. Works great. wolfSSL is open source for non-commercial use.
RE: RE: W5500 Support SSL ?
by hiprakashp ·
Thanks
by Mxyxixptlick ·
You may want to consider using my version of Paul Stoffregen’s W5500-compatible library. I made substantial improvements to its reliability and give the application more control of socket management.
https://github.com/SapientHetero/Ethernet
by hiprakashp ·
Thanks a lot for your reply…
Will check and update you.
