W5500 TCP server transmit data with Atmel128a
RE: W5500 TCP server transmit data with Atmel128a
by Arne db ·
I found out what the problem was… I had a mistake in my conversions of my pointers which made my MSB byte 0 every time… This caused sending a full buffer every time instead of 6 bytes.
Stupid mistake but now works like it should! I hope this helps other people if the same kind of problem occurs
RE: RE: W5500 TCP server transmit data with Atmel128a
by bhargav05 ·
I have a similar problem with the W5500 chip and it also sends out several frames with1460 bytes as data instead of 6 bytes that i want to send.
could you please elaborate the ‘pointer offset’ part in the 3rd step. I think this is something I am not doing.
An example with the offset address if possible would be very useful.
Thank you in advance.
