Has anyone used a W5500 with NXP S32K?
RE: Has anyone used a W5500 with NXP S32K?
by Matt Danecca ·
Or is there a SPI routine I could send to just transmit data without the library?
RE: RE: Has anyone used a W5500 with NXP S32K?
by louis ·
Hello
I’ll share the WIZnet iolibrary with you. Please refer to it.
by Matt Danecca ·
Hi Louis
I can’t link the library to my code unfortunately as I use a library block that just transmits the bytes I select over SPI when triggered.
Is there by any chance a simplified list of commands that I can send to get my W5500 chip to transmit test data just so I can check that the hardware design is correct?
Thank you very much!
