Datasheet - link - remaining "features" - Sending DATA?
RE: Datasheet - link - remaining "features" - Sending DATA?
by Shingadaddy ·
Can someone please help me understand not being able to read/verify the Sn_DIPR and SN_PORTR
registers? Within the forums I see it is a common misunderstood issue.
I’m using UDP, just trying to generate a blind transmit for now.
Socket reports OPEN in UDP mode. No pending Interrupts.
Thank you very much for a timely reply please
by Shingadaddy ·
Timely replies here are AMAZING! It’s like this person is inside my head
Well as usual I can now send messages on the network side. Amazing what a difference contiguous time on one fire can reveal. Mostly goofs on my side. The source data pointer to the data I wanted to send to the Sn_DIPR and Sn_DPORTR registers was getting whacked. I need to try re-reading those and see if I get what I expect. I hadn’t done that yet because I was so happy about seeing the network message I was wanting to send, I quit right there - on a high note- for the weekend. I’ll see if I can remember to try that later and post here since it might be comforting to someone else heading down this path.
