Mode Register Indirect.
RE: Mode Register Indirect.
by Shingadaddy ·
After micro starts up correctly I drive low
– the WIZ SCS pin (I DISABLE SPI) <<<< ---------- ERROR… Wrongo!
– the WIZ RESET LINE
Not verified OPTION 1 yet. Where just ADDR0 and 1 are set low(0) and just punch the READ line to see if mode register data shows up on the data lines.
BUT!
Option 2, using the Indirect method and the 2 IDM_ARx registers works - IF you catch the datasheet differences from the W5100 CHIP versus the W5100 implementation on the WIZ812MJ.
Specifically the fact that the WIZ812MJ fiddles with (INVERTS) the SPI ENABLE pin 31,
0= DISABLE , 1 = ENABLE.
Based on the level setting of the SCS signal pin 29. If you have the SCS signal low On the WIZ812MJ (like I did) this gets inverted and sent to the SEN pin 31. IE: Enables SPI mode. Exactly the opposite of what I wanted.
Writing registers, Reading registers and pinging. MUCH BETTER !
