Using W5500 as Bus-master in SPI Application
RE: Using W5500 as Bus-master in SPI Application
by bangbh ·
I don’t get you exactly but obvious thing is that w5500 only works as a slave.
To use W5500, u need a host MCU.
Like this
Ethernet connector ---------- W5500 ----- (spi) ----- MCU
by MoA ·
Thanks for replying.
Your answer is consistent with my understanding of how the W5500 works. I was thinking of using it like shown below, which is not possible because both the Ethernet encode and W5500 act as slaves.
Ethernet Encoder <----- SPI -----> W5500 <----- Ethernet ------>
Anyhow, I am now thinking about the arrangement shown below. According to W7500 documentation, it can be used as SPI slave or master. Do you see any problem with this approach?
Ethernet Encoder <----- SPI ----->W7500 <----- Ethernet ------->
Thanks,
Mo
RE: RE: Using W5500 as Bus-master in SPI Application
by bangbh ·
W7500 is a MCU with hardware TCP/IP stack.
I can’t tell you if it will work or not because I don’t know what exactly you want to do with ethernet encoder. I don’t even know what ethernet encoder does.
A more detailed explanation is needed.
