w5500 connection unstable
RE: w5500 connection unstable
W5500 does not support auto-MDIX feature.
Thus, user should use straight-through cables to connect to other switches or routers and crossover cables to connect to devices such as servers, workstations or another W5500.
However, user can use either type of cable to connect to other devices with auto-MDIX enabled, and the interface automatically corrects for any incorrect cabling. Must work with your switch though, but you may try changing cables and try another switch to see if there will be a difference.
RE: RE: w5500 connection unstable
by W5500Newbie ·
I tried many ways but finally I sort the problem out. I would supply ethernet board with arduino 3.3v pin. when I measure 3.3v pin and gnd, multimetre shows approx. 2.8 voltage and this makes me think problem may result from this voltage drop. Afterwards I supply ethernet board with another buck regulator with 3.4 volt dc. Problem has gone
Thanks for your support
Good luck
Please inform us of any problems as soon as they occur.
