W3150A+ SPI access to TX and RX buffers
RE: W3150A+ SPI access to TX and RX buffers
https://www.wiznet.io/wp-content/uploads/wiznethome/Chip/W3150A_Plus/Software/W3150A__DV_V109.zip
Please refer to the 3150A + iolibrary code.
Whenever you send 8-bit data, you must also transmit the opcode and address, and you need set high /SS and low again /SS.
Address does not automatically increase.
No, 70ns is write cycle time in bus mode.
In addition, network performance should consider not only spi but also mii interface speed.
The W3150a + 's network performance is Max. 25Mbps.
RE: RE: W3150A+ SPI access to TX and RX buffers
by marco ·
I’m sorry but at page 63 there is the following table:
At the sixth row there is the SCLK time minimum value, which is 70 ns. Is there an error in the datasheet or don’t I understand correctly?
If it is so, even if the max speed of the ethernet is 25Mb/s, the SPI access is the bottleneck of the comunication, isn’t it?
Thank you,
Marco
