TCP Disconnect not happening
RE: TCP Disconnect not happening
by Praveena ·
Please reply for my question as this is really IMPORTANT for my current work.
Thanks,
First, the Standard firmware of WIZ750 series not support HTTPS protocol.
Did you modified the firmware in order for you to use HTTPS?
Could you please attach the capture packet using wireshark?
RE: RE: TCP Disconnect not happening
by Praveena ·
Thanks for the reply. I am attaching the Wireshark log for the TCP-IP connection to HTTPS client.
Below are the main Modem configurations i did in WIZ modem here,
In the Wireshark log, the modem has been powered on at “2020-03-10 11:12:50” and the connection has been started to establish at “2020-03-10 11:12:52” by sending a SYN packet to remote host.
Later sending all the data, the application tries to disconnect the modem by sending “+++” command to modem, expecting to send a FIN packet to remote host around “2020-03-10 11:14:55”. But nothing happened and later the remote host has disconnected the active connection by sending RST packet after ~2 mins timeout.
WireShark-TCP-Disconnect-Issue-filtered.zip (17.1 KB)
I apologize for the late response.
You’re right. If you send “+++” command to modem during TCP operation, it must be send the FIN Packet from module to PC.
I’m not the person in charge of the matter.I’ll let the person in charge know this problem.
Requests
by Praveena ·
WIZ1.zip (100.9 KB)
Attached the Configtool images.
by Praveena ·
Device type is W7500S2E-R1. The software version is 2.3.
Attached the Configtool images.WIZ1.zip (100.9 KB)
by Praveena ·
Please update on any progress on this issue. awaiting for your reply.
