ISP not detecting mega128
RE: ISP not detecting mega128
by Grompf ·
Thank-you for your answer.
In order to debug the whole thing, i bought some breadboard and arduino maker wires.
By using the power from wiznet baseboard and by connecting directly the wiz200 to the programmer pins and not by using the ISP connector of baseboard : i can program the module and itruns well. As instructed by the idle loop of my boot monitor, the RED LED0 is blinking at 0.5Hz.
So it seems that there is something on the baseboard (resistors like R31, drains, etc) not compatible with my ISP. I’ve got two choices now… either i spent time on debugging the baseboard, or i build an adapter myself with 3.3V regulator and the 3 needed connectors. I think i’ll do the later since it will allow me to give introductory lesson to kids by building a regulated power supply and soldering some connectors.
Regards,
Grompf
