About Wizfi360 EVB mini board ?
RE: About Wizfi360 EVB mini board ?
by rena ·
Yes, Most AT commands are implemented to be compatible with ESP8266.
Unfortunately, the Arduino IDE is not currently supported, but we will consider it internally.
And the AT command Firmware is only supported in binary file format.
Instead, the W600 SDK is open to the public. (WizFi360 is based on the W600 chip.)
There are SDK and related documents in the link below.
Please refer these.
RE: RE: About Wizfi360 EVB mini board ?
by biniz ·
OK, thanks for your infomation.
by lawrence WIZnet ·
Yes you can use Arduino IDE but not WizFi360-evb-mini.
If you want to use Arduino IDE, I can recommend you WizFi360-evb-shield.
There is a interface for arduino board and you can control WizFi360 through Arduino.
Here is some document links for ref.
These are talking about arduino http server & client examples
http://wizwiki.net/wiki/lib/exe/fetch.php/products:wizfi360:wizfi360ds:wizfi360_an_hs_v101e.pdf
http://wizwiki.net/wiki/lib/exe/fetch.php/products:wizfi360:wizfi360ds:wizfi360_an_hc_v101e.pdf
And this link has all documents for WizFi360
http://wizwiki.net/wiki/doku.php/products:wizfi360:wizfi360ds:start
by biniz ·
OK, thanks for your information.
