Disconnect Ethernet cable my program crach
RE: Disconnect Ethernet cable my program crach
In TCP communication, if there is no response for a certain time, a timeout occurs and the connection is lost. How long have you unplugged the ethernet cable? You can delay the timeout by modifying the firmware.
And we not provide watchdog code. you can add watchdog code in to this project(GitHub - Wiznet/WIZ550S2E: Serial to Ethernet Module based on W5500 & Cortex-M0).
Hi~
Error 10061 indicates no connection could be made because the target computer actively refused it. The most common cause is a misconfigured server, full server, firewall issue or incorrect Port specified by the client.
