w6100 evb code
RE: w6100 evb code
by dkay ·
Hi, edtp.
I think you set just one byte read and write functions like this. “reg_wizchip_spi_cbfunc(spi_rb, spi_wb,0,0);”
wiznet spi interface supports burst read and write.
In the getnetinfo function, many functions use burst read/write like WIZCHIP_READ_BUF/ WIZCHIP_WRITE_BUF.
You must set this function, too.
RE: RE: w6100 evb code
by edtp ·
Hi, dkay
Switched on DMA and now I have SPI response.
However, the WIZnet team really needs to post a DHCP example for Keil and STMCube.
by HBKim ·
TrueStudio 9.1 HAL 드라이버를 사용하고 있는데… 유사한 증상이있어 자료를 찾다가 궁금한 점이 있어 문의드립니다.
void W6100Initialze(void) 안에 현재
reg_wizchip_spi_cbfunc(W6100SpiReadByte, W6100SpiWriteByte, 0, 0); 이렇게 되어 있는데 구체적으로 어떤 function을 선언해 줘야하는것인가요?
Hercules로 확인해 보면
PHY OK.
Register value after W6100 initialize!
VERSION(200) = 00
Mac address: 00:00:00:00:00:00
IP address : 0.0.0.0
SM Mask : 0.0.0.0
Gate way : 0.0.0.0
DNS Server : 168.126.63.1
GW6 : 0000:0000:0000:0000:0000:0000:0000:0000
LLA : 0000:0000:0000:0000:0000:0000:0000:0000
GUA : 0000:0000:0000:0000:0000:0000:0000:0000
SUB6 : 0000:0000:0000:0000:0000:0000:0000:0000
NETCFGLOCK : 1
0:Opened, UDP loopback, port [50000] as IPv4 mode
이렇게 나오는데, #define DMA를 wizchip_init.h 파일에 선언해 주면…
PHY OK.
VERSION(200) = 00
Mac address: 00:08:dc:ff:ff:ff
IP address : 192.168.177.25
SM Mask : 255.255.255.0
Gate way : 192.168.177.1
LLA : FE80:0000:0000:0000:0208:DCFF:FE57:5725
SUB6 : FFFF:FFFF:FFFF:FFFF:0000:0000:0000:0000
NETCFGLOCK : 0
이렇게 표시가 됩니다.
RE: w6100 evb code
by taylor ·
Hello edtp,
Please refer to this attached zip file (W6100 Loopback Keil Project).
And you can find the W6100 EVB example on this repository: WIZnet ioLibrary & io6Library examples · GitHub.
20191010_W6100EVB_loopback_Hal.zip (2.8 MB)
by edtp ·
Thanks, taylor.
You post was helpful.
As I posted to dkay, the wiznet team should post an STMcube DHCP example.
I’m finding the learning curve on the 6100 library is quite steep even with prior 5500 experience.
I am pleased with the team’s choice of microcontroller for the 6100 evb.
RE: w6100 evb code
by HBKim ·
자체 해결했습니다… HAL 사용자중에 저와같은 경우가 있을것 같아 기록으로 남깁니다…
STMCube로 Truestudio HAL Driver를 사용하는것으로 설정하면. . . . .
MX_GPIO_Init();
MX_DMA_Init();
MX_ADC1_Init();
MX_IWDG_Init();
MX_RTC_Init();
MX_SPI1_Init();
MX_SPI2_Init();
MX_TIM4_Init();
MX_USART1_UART_Init();
MX_USART2_UART_Init();
MX_USART6_UART_Init();
이런식으로 메인함수에서 여러 설정과 함께 SPI가 먼저 선언됩니다.
20191010_W6100EVB_loopback_Hal.zip에서 설명한대로
spi_set_func(&hspi2);
BoardInitialze();
ctlwizchip(CW_SYS_UNLOCK,& syslock);
ctlnetwork(CN_SET_NETINFO,&gWIZNETINFO);
printf(“VERSION(%x) = %.2x \r\n”, VER,getVER());
print_network_information();
위와 같이 그대로 따라 했으면 되었을텐데 SPI가 먼저 선언되는 바람에 BoardInitialze();에서 spiInitailize();를 생략했기 때문이었습니다…
아래와 같이 정리를 하니 예제에 나와있는것 같이 잘 초기화가 진행되었습니다.
spi_set_func(&hspi1);
MX_SPI1_Init(); //먼저있던 SPI1을 이부분에서 선언…
W6100Initialze();
printf(“Register value after W6100 initialize!\r\n”);
그대로 따라했으면 되었을것을 괜힌 HAL을 탓했습니다…
