Difference between WIZ610io and WIZ850io
IO Modules
IO Modules
RE: Difference between WIZ610io and WIZ850io
by lawrence WIZnet ·
Hi, Sympatron
Right, as you said there is no h/w difference between wiz850io and wiz610io.
And io6library is almost the same with iolibrary.
There are some added ip6 funtions and the functions name little changed.
You can use your firmware based on io6library and could be no hard to use it.
Caz io6library developed based on 5500 iolibrary.
During processing, any questions or issues, please share it.
RE: RE: Difference between WIZ610io and WIZ850io
by Sympatron ·
Thank you very much for your fast reply!
I agree that it is probably not very difficult to migrate to io6Library, but is it possible to use the io6Library with W5500 modules? Or would it be easier to add W6100 support to the ioLibrary_Driver?
The problem is that I don’t want to permanently branch our firmware, but rather detect the module automatically or even better only use features supported by both modules.
Yes… I got what you want to do.
But until now, there is no perfect resource I can give you…
W6100 and W5500 are almost same. the interface and memory…
but the point pin map is difference and some registers are difference.
So, if you use iolibrary you need to work for pinmap and some registers.
And if you use io6library you have to make permanent branch…
Sorry for this.
by radomirpolach ·
What is the speed difference? I read somewhere that W5500 is 15mbit capable, is that true? Is W6100 faster?
Hi, @radomirpolach
W5500 SPI supports 80MHz and the speed is useally depending on MCU.
When you use the MCU full spec (SPI clock and DMA), you can check W5500 almost 15Mbit.
The below link shows W5500 speed test result
https://javakys.wordpress.com/2014/10/29/the-second-trial-on-enhancing-the-throughput-of-w5500/
And W6100 has the same SPI interface system of W5500
