AXI Test application
RE: AXI Test application
by lawrence WIZnet ·
do you mean ,on wireshark, sending data and receive data are exactly the same data?
could you share the packet info?
by grama ·
I don’t have Wireshark data readily to send. If necessary, I think I can re-create it.
But the scenerio is as follows:
Axi Test Application displays a “Data Invalid” MessageBox.
Since I don’t have the source for this, I would like to know why this error is displayed. Is the Axi App comparing the data sent to the data received?
The WizNet module may NOT send the same data (or the same number of bytes) it receives from the Axi App in my test scenario.
Giri
RE: RE: AXI Test application
Yes AX tool compare send data and receive data.
Could you check the receive buffer when you send specific data from AX tool ?
And even you can not find any difference, I recommend you install wireshark to check the packets between PC and WIZnet module.
You can download it here. it is opensource tool.
https://www.wireshark.org/download.html
by grama ·
How do I check the Receive buffer in AX Tool?
