TTL or RS-232?
RE: TTL or RS-232?
by leathmg1 ·
Looking at the schematic for the test board:
Based on the use of level shifters connecting the UARTs to the DB-9s, I’m assuming that the voltages are TTL 0V to 3.3V representing 0 and 1 respectively.
Can you confirm that?
RE: RE: TTL or RS-232?
by jameskim ·
Hello leathmg1,
Sorry for our late response.
Yes, you’re right.
We have wrong information which can make users confused in our datasheet.
UART signal of WIZ140SR and WIZ145SR is TTL, not RS232.
RS232 Transceivers are on the those Evaluation Board.
We’ll fix datasheet with correct information.
James.
