¿W5500 / Ethernet Shield 2 How to make it work without pin 10 (SCSn)
RE: ¿W5500 / Ethernet Shield 2 How to make it work without pin 10 (SCSn)
Hi~ Doelectric_Domotica
you’re right. The SCSn signal should be tied to Low(Always connected to GND). And , Data Phase length is controlled by OM[1:0] value (‘01’ / ‘10’ / ‘11’) which is the SPI Operation Mode Bits of the Control Phase.
Unfortunately, you can’t use the FDM mode using the Arduino Ethernet Library.
If you want to use the FDM, you should modify the Ethernet Library(I don’t know if I can fix that.)
thanks,
by Doelectric Domotica ·
Can do it?
RE: RE: ¿W5500 / Ethernet Shield 2 How to make it work without pin 10 (SCSn)
It seems hard to use.
Sorry for the confusion.
There is some “C” or C++ library that is not Arduino that uses the format FDM?
Hello, There is some “C” or C++ library that is not Arduino that uses the format FDM?
Hi~
This is github addreass of W5500 EVB.
These are libraries source code and example projects based on LPCXpresso IDE.
Thanks
by Mxyxixptlick ·
I haven’t tried this, but suspect you can edit w5500.cpp and comment out every occurrence of “SPI.endTransaction();” and every occurrence of “SPI.beginTransaction(SPI_ETHERNET_SETTINGS);” EXCEPT the one in W5100Class::init(void). This should leave the SPI connection to the W5500 active at all times.
