W5500 Multicast Join Multiple Groups?
RE: W5500 Multicast Join Multiple Groups?
by vanvught ·
Hi Crees, please below the code for the join. I have prefixed the socket API’s with _ in order to be able to test the code on Raspberry Pi Raspbian SPI interface (not conflicting with the Linux socket API’s).
I have not tried to call it for several universes. But basically, this function just generates the join message. What if we call it for each universe to receive ? Does that simply work?
Arjan
http://www.orangepi-dmx.org/allwinner-h3
RE: RE: W5500 Multicast Join Multiple Groups?
by vanvught ·
Forgot to mention, this is working with sACN E1.31. After the join, you can simply do a recvfrom. Note : the socket number 0 is hardcoded in the example below.
by vanvught ·
With reference to ioLibrary_Driver/socket.c at master · Wiznet/ioLibrary_Driver · GitHub
it is doing a close. So calling the join multiple times is not working.
Also, I am eager to know how to initiate multiple join’s for a single socket.
by crees ·
I may be going about this thought the wrong way (bad hack) Using MacRaw to receive all the multicast traffic so we don’t have to bind IP to socket and then use a custom subscribe packet function to tell the upstream switch/router what multicast streams we are interested in?
by crees ·
I found success receiving multiple multicast streams from different multicast groups in MACRAW mode. However the issue is now that my buffer can only handle so many and I need to learn how to utilize IGMP to subscribe to multiple Groups. I am still looking how to craft an IGMP subscribe function in MACRAW mode.
Anyone have any advice on IGMP code usage in MACRAW mode?
