UDP received port error
RE: UDP received port error
If you did not perform purge of the receive buffers of the PC (closed that socket, rebooted PC) it will return all the packets it was able to capture while buffer had space for packet data.
RE: RE: UDP received port error
by Serfedos ·
Thanks for the answer.
I see that a new packet sends from PC from new socket reachs W5300 at the same time it was send (made a trigger in FPGA logic analyzer) and I see that PC sends from a new port but W5300 returns old port which W5300 was bombarded.
Please explain if you have solved the issue. It is not clear if you made any conclusion so far. If you still have troubles please attach wireshark logs and explain what and where you see the issue.
