W5500 MACRAW mode and Interrupt Pin
RE: W5500 MACRAW mode and Interrupt Pin
This is very good question! Looking to the W5100 datasheet where you can see the driving algorithms, the chapter about MACRAW says that it is the same as UDP, but UDP may use interrupt for receiving. Thus I assume that if data is received, it should raise RECV bit of Sn_IR, and thus main interrupt signal.
Please check your code against the W5100 datasheet (chapter 5) and let us know.
by vipulpanch86 ·
Thanks Eugeny,
I understood the problem, I was setting IMR and SIMR registers, however i missed out on setting Sn_IMR.
Sn_IMR is zero by default, hence all the interrupts are masked out and it doesn’t signal SIR.
I am able to get the required interrupts now.
