WIZ752SR-120 it always returns to the factory settings :/
RE: WIZ752SR-120 it always returns to the factory settings :/
by rena ·
Hi, @Tomasz.
What version of the tool did you test?
Please test with the latest version of the configuration tool. (latest version: 0.5.4)
Refer to below links.
RE: RE: WIZ752SR-120 it always returns to the factory settings :/
by Tomasz ·
Hi, thanks for quick respons
I was tested for many version tool (0.5.0; 0.5.1; 0.5.2; 0.5.3; 0.5.4).
How many version firmware to WIZ752R-120?
Thomas
by rena ·
The configuration tool is constantly updated, so it is best to use the latest version. (0.5.4)
The firmware developer is on the business trip, so we will answer the question at next week.
by Tomasz ·
Ok, I will wait for firmware developer.
But, I was updated firmware to:
It was big mistake
How I can repair my module WIZ750SR-120.
Thanks for help me,
Thomas
by Ricky ·
Hi.
You should upload the firmware using the W7500 ISP Tool.
And you need a MAC tool to write MAC. WizMACTool_v20151127.zip (7.1 MB)
And you need a binary.WIZ75xSR.bin (71.8 KB)
Connect the tx, rx, and gnd of J2 to the PC using the serial (ttl) to usb converter.
Run the W7500 ISP Tool
With J4 shorted, press the reset button of module.(or power on)
Change the serial port to serial (ttl) to usb converter and click Open button.(You can check it from the port in Device Manager.)
When you are in download mode correctly, you can see “serial open complete” message at the bottom.
In Step 5, select the binary file and click the ISP start button.
Run the MAC Tool
Change the serial port to serial (ttl) to usb converter and click Connect.(Double-click to see the port.)
press the reset button or power on.
If you see “INPUT FIRST MAC?”, click the Write MAC button.
Please try it and let us know the results.
