Problem With W5100 Linking to Ethernet.
RE: Problem With W5100 Linking to Ethernet.
You left pin 33 (VCC1V8D) unconnected. Please refer to the reference circuit diagram.
You circuit driving SEN pins looks strange. You do not plan to use chip in parallel access mode, why you complicate the circuit? If you use SPI only, pull SEN up.
RE: RE: Problem With W5100 Linking to Ethernet.
by mcelliers ·
Hi Eugeny. Thank you for your comment. It helped me a lot.
I also see that I Left out Pin 74 (1.8V_A) and pin 69 (1.8V_d)
As soon as I connected these, I got the Ethernet to function properly.
Thanks again!
Regards
Marius
