Configurations
RE: Configurations
Hi Y_Murga,
You can use the following two methods for the operation of the WIZ107SR module you want.
The inactivity timer is a function to terminate a TCP connection if data transfer does not occur within a specified time.
Below link will help you.
This link is the user’s guide for WIZ750SR module which is the hardware and software compatible with WIZ107SR product.
https://wizwiki.net/wiki/doku.php?id=products:wiz750sr:usermanual:start#tcp_server_client_mixed_mode
RE: RE: Configurations
by Y Murga ·
It has helped us a lot! Thanks!
Best regards
