Communication issue with 550sr
RE: Communication issue with 550sr
Hi.
First, refer to below link.
http://wizwiki.net/wiki/doku.php?id=products:wiz550sr:wiz550sr_userguide_en
lt link is 550sr configuration tool guide.
And, Did you checked AT command enable check box in configuration tool?
It must be checked in box.
And Did you setting 2B, 2B, 2B code?
It was ASCII code. So, setting to 2B(+) , 2B(+), 2B(+).
And AT command operation must be added to $0d$0a(\r\n) in a packet.(tail)
It is using HEX code.
RE: RE: Communication issue with 550sr
by tora ·
Yes, AT command check box is enabled and code is set to 2B,2B, 2B (ie, mentioned +++).
0D,0A was added to end of AT commands.
Yet module doesn’t seem to be responding anything via serial port, while ethernet side seems to be working fine. I assume that since I am able to fetch configuration data with Wiznet config tool, the module is in correct operating mode where it should accept also AT commands?
Hi.
First, Did you used wiz550sr-evb?
If you not used wiz550sr-evb, You connect to wire or another boards.
WIZ550sr has 2 serial ports. (Data communication port is UART 1)
And UART2 is display debug message port.
So, you must be send “+++” mesage to UART1.
And then check the messag.(below message)
[W,0]
[S,0]
by tora ·
Module is on custom board that connects to our MCU board. I am using J2 pins 1 (for sending data to wiz550) and 2 (reading data from wiz550) (so, UART1) to connect the module to serial port of our main board MCU. Flow control (pins 3,4) is not currently used, as indicated by config tool.
I have sent “+++” message to UART1 (pin 1). I have verified with oscilloscope with serial decode that data sent to module is valid and has correct parameters. After this there I see absolutely no activity of any kind on pin 2, it remains high all the time.
Edit:
I suspect that there is some issue with initialization/startup sequence (ie, timing how power, /reset and /hwtrig lines should be controlled during startup?). Now the board is working as expected although nothing was changed between previous attempts and now except power cycling entire project overnight.
Also, is there any explanation about three board leds (red + 2 green), what do they exactly signify?
