WizFi250 Timeout Settings
RE: WizFi250 Timeout Settings
Hi, GOHS
Can I get some materials regarding your questions?
→ How did you use the AT command? Did you try like this? ‘AT+FSOCK=1,15000’
If you didn’t, try like that. Or if you did like that, please attach the screenshot to check the DBG messages.
→ I think it is also same things. please try ‘AT+FSOCK=1,20000’ (max.20000ms)
Thanks!
RE: RE: WizFi250 Timeout Settings
by GOHS ·
Hi tom,
thanks for the quick reply.
I used the command like in the Wiki examples
AT+FSOCK=1,10000
and expected a 10 seconds timout, but it remained 5 seconds.
I just tried it once more as You mentioned, just in case…
… manual initialisation, then AP join …
[Link-Up Event]
IP Addr : 192.168.103.42 ← IP from DHCP
Gateway : 192.168.103.254
[OK]
at+fping=5,192.168.103.254 ← ping Gateway
Ping Reply : 40 ms
Ping Reply : 6 ms
Ping Reply : 4 ms
Ping Reply : 4 ms
Ping Reply : 5 ms
[OK]
at+fsock=?
5000,5000,5,100,0,0,0 ← settings at power on
[OK]
at+fsock=1,15000 ← chaged option 1 to 15 seconds
[OK]
AT+SCON=O,TCN,192.168.103.216,5611,1 ← connect to unavailable IP/port
[OK]
… 5 seconds …
[DISCONNECT 0]
at+fsock=?
15000,5000,5,100,0,0,0 ← option 1 ist set as wanted
[OK]
… set up listening server PC running realterm …
at+fsock=1,20000
[OK]
at+fsock=?
20000,5000,5,100,0,0,0 ← option 1 set to 20 seconds
[OK]
AT+SCON=O,TCN,192.168.103.40,5611,1
[CONNECT 0]
[OK]
… sent ‘test’ over Wizfi and received it on PC (realterm) …
… disconnected AP from LAN waited 30 seconds: as expected no change …
… sent ‘t’, then waited ca. 12 (?) seconds until …
[DISCONNECT 0]
In each case the option 1 of FSOCK seems to have no influence on the mentioned timeouts.
Hope this is what You wanted to see.
Hi, GOHS
I misunderstood some parts.
There is no way to set a TCP timeout value.
As you know, in case of disconnected environment, there is how to reconnect every specific seconds.
I am sorry for this.
Thanks,
by GOHS ·
Thanks for the info.
Would be nice if the exact timeouts would be mentioned in the WiFi250 wiki.
Greetings!
by phil31 ·
would be nice if the commands list and definitions are right describe and update !
