Stream data transmitting with W7500P
RE: Stream data transmitting with W7500P
Hi Ilya.
First, What use device? WIZwiki-W7500P? or WIZ750SR? or your board(made)?
and We need your test code.
If you send to me, I will check your firmware code.
by Ilya ·
We use the board, which was made by ourself. We made three boards and they have different routing. And only one board sometimes works normally. We send a part of our code.test_code.zip (1,0 КБ)
by igrowagarden ·
I have the WizWiki 7500P dev kit I have this exact same problem. Any word on this? I stream every 0.1 seconds from the ethernet and every couple seconds the ethernet just seems to take a break for upwards of several seconds.
RE: RE: Stream data transmitting with W7500P
by Ilya ·
Hello! You tried to use 10 Mbits mode???
by igrowagarden ·
No I’m auto negotiating 100mbps. Does 10mbps work better?
by Ilya ·
Yes. See Buggy w7500p?.
Hi.
W7500P has already revision.
If you use before version to W7500P, I recommend that change W7500P revision chip.
