W7500 raw socket
RE: W7500 raw socket
hello,
W7500 supports IPRAW and MACRAW socket. But there is no RAW socket example running on W7500.
You can use it by modifying the W5500 document Since W7500 contains W5500 core.
W5500 document has an ipraw application note PPPoE communication application note running on macraw socket.
http://wizwiki.net/wiki/doku.php?id=products:w5500:application
Thankyou
RE: RE: W7500 raw socket
by dollyparton ·
I managed to get this working by modifying the driver send function, adding a RAW constant to the enum protocol definition and creating a Raw socket class. Details of changes below.
W7500x_toe.cpp - Added sendRaw function. This is identical to send except it uses SEND_MAC instead of SEND as the command. Could modify send to check the protocol and use the appropriate command. For now I have two functions.
W7500x_toe.h - Added RAW to the protocol enum:
SocketRaw.cpp - New class derived from Socket, that uses the above:
by dollyparton ·
Thanks Becky. I managed to get it working well. I have posted my solution onto the thread for others to use.
by Muralidhar ·
We are using W7500 as Serial to Ethernet Converter. Where we need multiple sockets too. from the W7500X libraries, We found Socket.c and socket.h files , but these are some what confusing. Can you please share your code for Serial to Ethernet if you done it.
it will be helpful to us.
