Unable to read the TX Buffer of w5500
RE: Unable to read the TX Buffer of w5500
by jim ·
Dear dhanunjay
What kind of type is your MCU?
First of all, please check SPI operation between MCU and W5500. Is it work?
And then refer to loopback_tcps() function in loopback.c file. (GitHub - Wiznet/ioLibrary_Driver: ioLibrary_Driver can be used for the application design of WIZnet TCP/IP chips as W5500, W5300, W5200, W5100 W5100S. )
The following all cases were released products.
NXP case:
Please refer to SPI Interface in GitHub - Wiznet/WIZ550S2E: Serial to Ethernet Module based on W5500 & Cortex-M0 or GitHub - Wiznet/W5500_EVB: W5500-EVB Library and Examples
ST case:
Refer to SPI Interface in GitHub - Wiznet/WIZ550SR: Serial to Ethernet Module based on W5500 & Cortex-M3 or GitHub - Wiznet/WIZ550web: Webserver application with W5500 for things (Non-OS)
And last, please confirm schematic files by WIZnet. (support@wiznet.io)
RE: RE: Unable to read the TX Buffer of w5500
by dhanunjay ·
Hi jim,
I am using pic18f45k22 micro controllers. SPI between pic and w5500 is working, i have tested the loopback tcp.
Problem is i am unable to send the a TCP Packet with size of 1514 bytes. I am trying to fill the TX buffer with 1460 and then change the command register to the send command. but when i did that i am only seeing the last set i am writing to the TX buffer.
