W5500 TCP Server is refusing to connect
RE: W5500 TCP Server is refusing to connect
Insufficient information. What your socket_write calls are expected to do? Which values socket_read gives?
RE: RE: W5500 TCP Server is refusing to connect
by dhanunjay ·
My socket_write and socket_read just write and read the register of socket 0.
here is the code:
Hi dhanunjay,
When implementing a TCP server device based on the W5500 chip, please refer to the loopback_tcps() function of the next github link as a skeleton.
There is a caution. Please do not use delay() function when implementing networking applications. Network application devices (especially for a TCP server) must be able to receive client connection requests at any time. These delay routines in while loop can cause client connection failure and timeout.
by dhanunjay ·
Here is the packet capture from the wireshark 192.168.0.150 is my w5500 TCP Server ip and other my pc.
Here my total code
So your PC sends SYN packet to establish new connection, but W5500 responds with RST/ACK packet. I can not understand algorithm from your code, but probably you confused server-side W5500 implementation and client-side implementation.
When your PC connects to the W5500, W5500 sends required data to the PC, and at the end of this data stream W5500 must perform disconnect, and only then close commands. Disconnect command is being performed while W5500, as a server, is in “established” state, thus your code
may simply never execute when server needs to terminate the connection, and W5500 does not perform disconnect (internally to itself, and informing PC that it has finished with data).
Please revise your algorithm, and see which case statements are being executed, and when.
