W7100A-S2E not found on TCP-IP
RE: W7100A-S2E not found on TCP-IP
by lawrence WIZnet ·
hello, electros
thank you for your question.
Now, we are concerned about this issue.
Sooner or later, we will support you with it.
So sorry about that I could not solve clearly.
thank you,
lawrence
Dear electros,
I recommend you to try the firmware update as the first way to solve the problem.
I attach the W7100A-S2E-64QFN latest firmware - version 4.06 - for you.
W7100A-S2E-QFN64_v4_06.zip (21.9 KB)
Note) Attached application firmware binary is dedicated to the 64QFN package chips.
Please perform (1) firmware update and (2) search + factory reset of the device and report the result to us.
I hope you to solve the problem quickly.
Regards,
Eric
Dear electros,
I will add additional information for you.
All our W7100A series package chips are MSL 3 (Moisture Sensitivity Level).
The meaning of this is the description of the attached image, and baking before board mounting is required after a long time has elapsed since the vacuum packaging of the chip was unpacked.
Regards,
Eric
by fsisma ·
Thank you Eric,
I am a colleague of electros.
we will try with the firmware for the 64QFN package as soon as possible. In our country now is holiday and the factory is closed.
We will report the result next week.
At the moment I’m at home and I have only an electronic board with the W7100A-64QFN chip (not the s2e version).
I tried to install the firmware with WizISP in this card but it doesn’t work.
Next week we will try to install it with Configuration Tool by Ethernet in the cards with W7100A-64QFN-s2e chip version
Best regards
Dear fsisma,
Our W7100A-S2E firmware of the product consists of two parts(Application boot part and app part), only the app part is released (60kB size). Released firmware at website is used for firmware update using configuration tool only.
If the mentioned issue is not resolved by a firmware update, it may be a problem by moisture depending on storage.
Please try to chip baking before mounting and tell us your hardware production results.
Regards,
Eric
by electros ·
Dear Eric,
I’m glad to inform you that the firmware 4.06 you provided us has solved the problem. Now all the ‘faulty’ boards are immediately detected by the config tool and work correctly.
Thank You very much, I really appreciate your help!
Electros
by Andres Romo ·
@irina_kim , I am working in a similar project and the same issue with the Ethernet connectivity is happening, and I would like to update the FW of the unit, but we are using a different package of the W7100-S2E-100, could you share the FW used for that package: 100LQFP
