W7100-S2E mixes messages bytes
RE: W7100-S2E mixes messages bytes
by jameskim ·
Hello Mich,
Old version firmware has such a bug which you had but it is fixed in the latest version, 4.06.
You can download it from the below link.
[url]http://www.wiznet.io/product-item/wiz107sr/[/url]
You can update W7100A-S2E with the latest firmware via WIZ107/108SR Configuration Tool on the above line as well.
Ver 4.06 firmware operates like below.
In TCP Client mode, all serial data before TCP connection is not stored in Serial RX buffer on W7100A-S2E.
Whereas, in TCP Mixed mode, all serial data before TCP connection is stored until it reaches to the size of Serial RX buffer and following data will be discarded not to make buffer overflow and overwrite previous data.
If you want to keep data from serial before TCP Connection, I recommend you use TCP Mixed mode.
With TCP Client mode, you will loose all data before TCP connection.
BR,
James.
