[W7500P] PB_06 alternate function
RE: [W7500P] PB_06 alternate function
by lawrence WIZnet ·
Hello, pherig
Yes!
The pin PB_06 is possible to be used as GPIO too.
And it is so sorry to guide confused documents.
We will correct as soon as possible.
Thank you so much,
lawrence
by AMWJ ·
Greetings,
are you using the default libraries? Maybe the following code will help you, let me know if it works for you.
by nda ·
PB_06 doesnot work as GPIO!!! According to the table 10 in section 12.3 of W7500P Reference Manual
Version 1.0.3 it has such function, but according to 15.6.2 it doesnot have such function. I’ve tried. It doesnot work!
RE: RE: [W7500P] PB_06 alternate function
hello nda
sorry for late reply.
the new w7500x datasheet said that PB_6 does not work as GPIO anymore in table 4 (only dup)
please refer the below link
https://wizwiki.net/wiki/lib/exe/fetch.php?media=products:w7500:w7500x_ds_v107_20180727_.pdf
thank you
by leejin0 ·
I am very confused. because I am using PB06 of W7500p as GPIO now.
Of course, the datasheets were shown to be available only as DUP, but I ignored that.
And I’ve written code that toggles the pin every 0.5 seconds.
And it works well.
