Easier batch programming of WIZ107SR
RE: Easier batch programming of WIZ107SR
Hi.
I’m answer for you.
Thank you for your opinion.
First, WIZ107SR possible to window 10 environments. We checked this test.
And, What use config tool version? last version is 1.4.4.2. (too 1.4.4.1 version OK)
I think, you possible choissing two options.
UDP broadcast
→ It is possible send to same network area. and receive to response message from same network area on device.
TCP 1:1 communication.
→ I think, TCP mode is fast more than UDP because UDP is sending all network area.
So, I’m request to test for you. To TCP, UDP test.
