Arduino SERVER TCP. Send data packet struct
RE: Arduino SERVER TCP. Send data packet struct
by Kei ·
Hello, svia.
Arduino Library of W5500 chip is ethernet2.
In 1.6 you need to add ethernet2 directly.
From 1.8.0, however, you can add ethernet2 through the arduino library manager.
First, add / change the library.
And the write () function of the EthernetServer class has a fixed parameter type as shown below.
size_t EthernetServer::write(const uint8_t *buffer, size_t size)
[url]https://github.com/adafruit/Ethernet2/blob/master/src/EthernetServer.cpp[/url]
Therefore, the custom type of the structure can not be the parameter of the function.
If you want to manage data like structs, it’s a good idea to define and manage array numbers or manage them with pointers.
Of course, if you really want to use a structure, you can use C ++ Function Overloading to change the parameters and reconstruct the function.
I hope that helps.
Best regard,
Kei
