Wizfi250: server web?
RE: Wizfi250: server web?
by cliff ·
There is condition to perform “SSEND” command.
First, UART DATA must be entered in 3 seconds.
Also, Total length of the data want to send, must be input within 10s + (Total Length)ms.
If both of the above conditions are not met, Timeout occurs.
by stephaneroque ·
thanks for your answer, but i don’t understand when the timer start.
I think, the timer start after this command AT+SSEND and not before.
Example:
https://wizdaniel.wordpress.com/2015/08/17/wizfi250_ssl_connection/
[code]AT+SSEND=0,146
Google[0,146]
[OK][/code]
The answer for this example is [0,146] and not [ERROR: INVALID INPUT]
I have 1s beetween AT+SCON=O,TSN,5000,0 and AT+SSEND=0,146
i try to insert less.
by cliff ·
Yes, the timer start just after entered AT+SSEND command.
