API for Development
RE: API for Development
Hi.
Sorry… We not have AJAX information documents…
Web have just simple documents.
refer to below URL. It is simple document. (web page)
wizwiki.net/wiki/doku.php?id=pro … 0webgsg_en
And refer to below URL. It is web page download URL.
github.com/Wiznet/WIZ550web
by blahblah ·
Thanks for your reply. Since there is no information on how your application works, I was hoping that you could answer a few questions for me?
(index):265 POST 192.168.11.100/dout.cgi net::ERR_CONNECTION_REFUSED
AJAX.doPost @ (index):265
(anonymous function) @ (index):390
I was also wondering how I can check the state of a pin, whether or not is is Hi or low?
Thanks!
function postdataPinState(pinNumber,pinState){
var p=pinNumber;
var v = pinState;
dout_timer=setTimeout(function(){
if(dout && dout.abort){dout.abort();}
dout=new AJAX(‘dout.cgi’,function(t){
try{eval(t);}catch(e){alert(e);}
dout.doPost(‘pin=’+p+‘&val=’+v);
},300);
function postdataPinDir(pinNumber,pinDirection){
var p=pinNumber;
var v = pinDirection;
dout=new AJAX(‘dir_change.cgi’,function(t){
try{eval(t);}catch(e){alert(e);console.log(t);}
dout.doPost(‘pin=’+p+‘&dir=’+v);
},300);
function myDelay(myDelayTime){
for(var i=0; i<myDelayTime;){
i++;
function setAddrToVersion(){
function setDataBusToInput(){
function setDataBusToOutput(){
function getRevisionNum(){
by blahblah ·
I would also like to know how to read the status of an actual pin without having to check the html alias/name.
Thanks!
by blahblah ·
Nevermind… as if you were actually working on it.
There are two ways to do what I wanted.
use JQuery and the when() then() methods
simply make ajax synchronus (this is what I used)
function AJAX(url, callback)
var req = AJAX_init();
req.onreadystatechange = AJAX_processRequest;
