Ethernet configuration protocol
RE: Ethernet configuration protocol
by jameskim ·
Please refer to the below attachment.
Message Structure and Message Flow in WIZ14xSR.pdf (92 KB)
Thx.
javakys
by rmg ·
Tahnk you
by DaveB ·
The pdf documentation seems to be incorrect regarding the byte order of the LPort field. It appears that the word is in Little Endian (LH) order, so it should be:
ChannelInfo.LPort [2 Bytes, it indicates the Local Port number of the socket]
Example) If Local Port is 5000 ( = 0x1388), then LPort[0] = 0x88, LPort[1] = 0x13
instead of the PDF where it shows:
Example) If Local Port is 5000 ( = 0x1388), then LPort[0] = 0x13, LPort[1] = 0x88
I looked at the UDP packet sent/received by the WIZ14xSRConfig_Rev 1.7 utility.
