W7500P - access to IP101G
RE: W7500P - access to IP101G
by ezheng ·
I also have the same question.
Edward and Lawrence, Can you take a short time to look at this question?
Thanks very much,
Ed
by Innotas ·
I have the same problem. The network link to the W7500P not working.
phy id detect error !!
by oetelaar ·
I looked at the code from github github.com/Wiznet/W7500P
at the file: W7500P/W7500P_FW/ioLibrary/MDIO/W7500x_miim.c
This contains code to access the PHY chip.
However, if the PHY is not responding, it might be that it is using the wrong address.
I would first check the PHY_AD0, PHY_AD1, PHY_AD3 and make sure the LED’s are connected correctly.
The datasheet of the IP101G shows how to set the address of the PHY on page 47 of bdtic.com/DataSheet/ICplus/I … 121224.pdf
Hope that helps.
Edwin van den Oetelaar (Netherlands)
by ezheng ·
W7500P embedded the function of IP101G. But I think the data sheet and reference of W7500P need to update to clearly show the attribute and application of W7500P.
Let’s look at the code from github github.com/Wiznet/W7500P
Example #1
#ifdef W7500P
// PB_05, PB_12 pull down
*(volatile uint32_t *)(0x41003070) = 0x61;
*(volatile uint32_t *)(0x41003054) = 0x61;
#endif
Comment: When refer to the reference and data sheet of W7500P, there are no definition of address of (0x41003070) and (0x41003054) , nor of PB_05 and PB_12
Example #2 main()
mdio_init(GPIOB, MDC, MDIO) // #define MDIO GPIO_Pin_15 #define MDC GPIO_Pin_14
Comment: W7500P do not define PB_14 and PB_15
The question raised by Winston is critical to W7500P’s application, I wonder why this question is still open after 4 month。
Ed Zheng
by lawrence WIZnet ·
Hello, all
Thank you for your interests with W7500P.
At the first, Sorry about no PHY reference document in W7500P ref.
It will be updated soon on http://www.wizwiki.net > W7500P Document page.
Sooner or later I will notice here.
Thank you so much
lawrence
Hello All,
There is a 7500p PHY reference updated.
[url]http://wizwiki.net/wiki/doku.php?id=products:w7500p:documents[/url]
And soon, MDC MDIO pin register also updated.
So sorry about getting late.
It will be modified and updated more and more.
Thank you so much.
lawrence
