SSL support in the WIZ550io
RE: SSL support in the WIZ550io
by Coccoliso ·
SSL is only a protocol.
HW side there are no problems but FW side is required data encription with certificate exchange and I am not aware that there is currently an Arduino library (most common MPU hw) to do it.
If you find an example would be the case of share it and adapt it to other cases.
WIZnet doesn’t support about SSL officially. But trying to make SSL protocol.
And SSL is protocol so you can use to make firmware.
