Disable Wifi
RE: Disable Wifi
by ssekim ·
Hello Jasenharris
As I know, there is no command to disable WiFi in WIZ610wi.
Even GP command can’t disable WiFi perfectly.
RE: Disable Wifi
by kaizen ·
Hi
WIZ610wi can’t disable Wi-Fi using serial command and web configuration.
But there is expedient to disable Wi-Fi on WIZ610wi. If WIZ610wi change the operation mode to Client using command, WIZ610 will be off the AP signal because it will be changed to Client mode.
It is expedient method, So It needs your judge.
RE: Disable Wifi
by jasenharris ·
Are there any other work arounds available? What I really need to do is to completely disable the tx signal so that It can’t be seen by any other rf receiver. When the device is in client mode but not connected, does the wifi transmit a signal or is it in passive scanning mode?
Thanks
RE: Disable Wifi
by ssekim ·
Hello Jasenharris
As I know, there is no work-around way.
Sorry for that.
