Serial Command Mode Crash
RE: Serial Command Mode Crash
by ssekim ·
Hello Paul
(1)
I couldn’t reproduce what you said.
What is the serial-terminal-tool which you used?
How about try it again with another terminal-program?
(2)
I’m not sure why the module didn’t respond.
But, about this issue, I want you to confirm the response for each command.
by SomeUser ·
I have resolved Issue #1. I was using a ATEN usb to serial converter, it doesn’t like the flow control connected but not used. My resolution is to only connect the TX, RX and GND pins, then the terminal is almost perfect (issue #2 remains)
As for Issue #2:
I have set my terminal program to echo my typed characters here is the response:
<Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28><Sv1.1.28>
<Sv1.1.28><Sv1.1.28>[color=#FF0000]>[/color]<RF
(I’m using real term, but the problem exists for HyperTerminal and putty, infact I’m trying to use the module with an embedded MCU, and this is where I found this problem. My MCU was communicating with module before it was powered and running, sometimes the module didn’t respond. Upon debugging I discovered this feature)
Thanks,
Paul
by ssekim ·
Hello
I tested it again.
As you said, after extra “>”, WizFi630 didn’t respond, but after some seoncds, it responded it after some seconds.
Refer to the below. (I tested it with v1.1.31)
