Is there a way to increase power?
RE: Is there a way to increase power?
by borisj ·
Perhaps you could use the at command AT+WBGN
wizwiki.net/wiki/doku.php?id=pro … et#at_wbgn
I don’t know how to use it though, the website does not give any details, just recommends that you should not use it unless it’s absolutely necessary - in your case it might be…
by ssekim ·
Hi anglial
How about trying it again after changing the antenna-option?
AT+WANT Antenna Configuration =? or = (0:uFL,1:PA,3:Auto)
by anglial ·
Thanks I will try using the AT+WANT command today.
I would like to see what affect AT+WBGN has as well
The AT+WBGN command accepts 0,1 or 2
What do the 0,1 and 2 refer to ?
Is there a default ?
at+wbgn=0
[OK]
at+wbgn=1
[OK]
at+wbgn=2
[OK]
at+wbgn=3
[ERROR: INVALID INPUT]
at+wbgn=?
by ssekim ·
Hello anglial
You can fix a b/g/n WiFi mode using below command.
You should issue this command before AT+WJOIN.
But, I’m not sure that this can solve your problem.
AT+WBGN : WiFi 802.11bgn mode Configuration = (0:bgn, 1:bg, 2:b)
Ex)
AT+WBGN=2
[OK]
