Using WIZ140SR with Wiznet VSP
RE: Using WIZ140SR with Wiznet VSP
by jbkim ·
Please check the “Eltima Serial To Ethernet Connector Service” is registered in the Windows Service.
If not, execute the “install.bat” file under “Program Files\WIZnet\WIZ VSP” folder with administrator privilege.
After service registration, make sure it’s property is “automatically start” and the status is “started”.
If above method is not working, register the "“Program Files\WIZnet\WIZ VSP\reboot_sec.bat” in the Windows Startup Program.
by Dave81 ·
I have the same problem! The driver is registered and started.
After each restart all COM ports have disappeared in the device manager.
It is also not possible in the VSP to edit the connection.
Windows 7 Professional 32Bit SP 1
VSP 1.6.1
