WDS Autoreconnect
RE: WDS Autoreconnect
by kaizen ·
Hi
I need your network environment in order to more accurate analysis about this issue.
For example, Did you use other AP for connecting Internet. in other words, Did you have another AP for using WAN?
If not, Did you set WizFi630 with the purpose of using WAN?
by frankr ·
Hi Kaizen,
Sorry for the late reply, I was busy and didn’t check the forum for a while.
Here my network environment: no WAN, no other AP. I simply want to put a repeater between AP+WDS (Wiz610wi) and a laptop.
[url]Dropbox - Error
Since WizFi630 is set up as AP, I guess there is no WAN concept. Right?
Hopefully this information is helpful otherwise please let me know.
Thanks,
Frank
by kaizen ·
Hi
We did test about issue in our laboratory. We also witness same phenomenon.
So we will modify this problem. But we need time roughly 1 ~ 2 month.
by frankr ·
Hi Kaizen,
Is this modification going to affect both firmwares: WizFi630 and Wiz610wi?
Are you going to keep me informed when the new firmware(s) will be available?
Thanks,
Frank
by kaizen ·
Hi
This is my answer.
